S12Z weak function
已解决
S12Z weak function
跳至解决方案
6,546 次查看
francoisdugue
I'm working with S12ZVL devices, and i try to use "weak" function attribute.
I don't find any clear statement (or example) on S12Z, that this attribute is available or not.
Can you help me on this subject?
Thanks in advance.
1 解答
6,513 次查看
StanoA
Hi Francois,
I’m sorry that it don’t help you.
I made test for Kinetis MCU in the same CW IDE and it is supported. My understanding is this attribute is not supported by S12 Compiler. The ARM Kinetis use the GCC which supports this option. In case I take such suggestion how to solve it I will send you message.
Sorry I can’t help you more.
Stano.
在原帖中查看解决方案
7 回复数
6,533 次查看
francoisdugue
Thank you for this answer.
As your link is about Kinetis devices (not the same tool chain) i'll do some tests.
I'll keep you informed.
Thank you
6,530 次查看
StanoA
You are welcome.
6,540 次查看
StanoA
Hi Francois,
Sorry we haven’t code example for this attribute usage.
But the S12Z family of MCUs is supported by our CodeWarrior IDE (v11.1) and the “weak” attribute is supported also. You can see it in:
https://www.nxp.com/docs/en/reference-manual/CWMCUGCCCMPREF.pdf
on page 40.
The CW IDE 10.x is the predecessor of the CW IDE v11.1.
I hope it could help you in your task.
Stano.
6,523 次查看
francoisdugue
Unfortunately it doesn't work.
=extern bool_t bTask_1_Init(void) __attribute__((weak, alias("bNullInit")));
>illegal or unsupported __attribute__
Maybe i miss something. Do you have any idea?
Thank in advance.
6,513 次查看
StanoA
Hi Francois,
Stano.
6,510 次查看
francoisdugue
So, we have the same conclusion.
S12Z toolchain doesn't support weak function attribute.
Thank you for your support.
6,506 次查看
StanoA
Thank you for your answer.
You are welcome.
Stano.
