Read Accumulator Register from C
4,963件の閲覧回数
jimw
Is there a simple efficient way to move the contents of Reg A to a variable in C?
タグ(1)
2,211件の閲覧回数
jimw
I think I found it.
char t;
 __asm {
 sta t
compiles as:
  TSX
  STA ,X
2,211件の閲覧回数
bigmac
Specialist III
Hello JimW,
Whenever a function returns a char value, the returned value will be in the accumulator.  So the following seems to work OK.
char funcA(void) {
  asm lda TCNTL;   /* Low byte of timer reg */
char value;
value = funcA();
Mac
2,212件の閲覧回数
jimw
I think I found it.
char t;
 __asm {
 sta t
compiles as:
  TSX
  STA ,X
