Programming External Flash using CFv2 JTAG
kunalgaur
we are using a custom board, with Coldfire V2 processor, and external Spansion flash. earlier the board was using BDM interface, and programming spansion flash was easy using P&E micro CYCLONE MAX. however due to design change in custom board, currently we are using JTAG interface instead of BDM.
I have this query for programming external flash using JTAG interface, as P&E micro does not support programming from JTAG.
Does anyone know any tool available in market which can support programming to external flash with CFv2 JTAG support?
Thanks & Regards,
Kunal Gaur
TICS_Fiona
Hello kunal
Sorry please be note that ColdFire debugging and programming can only be done with BDM. JTAG is only for scan testing.
Best Regards
Fiona Kuang
Technical Information & Commercial Support
TICS_Fiona
Hello kunal
Best Regards
Fiona Kuang
kunalgaur
Thank you.
Kunal Gaur
