Problem with banked memory model
2,497 次查看
MarcosAquino_Ch
Hi !
I'm using AC128 with codewarrior 6.2.  The codewarrior show de message : L1102: Out of allocation space in segment ROM at address 0x7FE5. I don't undestrand how to use banked model now....
Somebody help me?
(Sorry for my bad english, i'm a punk and don't go to school...)
标记 (1)
2,095 次查看
kef
Specialist I
AC128 default prm file places nonbanked routines and constants only to segment ROM (20f0-7fff). It looks like you are out of this nonbanked space. To use ROM1 (c000-ff9b) for nonbanked routines and data you should:
1) Find INTO ROM; in your prm file and change it to INTO ROM, ROM1;
2) You need to add -OnB=b compiler switch to compiler command line. Or go to compiler setting and enable Disable Branch Optimizer = Disable Branch JSR to BSR optimization.
2,096 次查看
kef
Specialist I
2,095 次查看
MarcosAquino_Ch
tks man!!
