Please fix the error TRK-MPC5606B
1,870件の閲覧回数
sonhowon
Hi.
I using the CodeWarrior IDE (CW for MPC55xx, MPC56xx 2.10) compiler
Project -> Make
Project -> Debug
Setting is RAM is in good operation.
Setting is internal_FLASH
But it did not download below. (Please check the attached file)
TRK-MPC5606B
Programming Address $00000000 Error during programming
ERROR 18 during script
タグ(1)
1,633件の閲覧回数
martin_kovar
in PEMICRO Connection Manager select CPU Target Information MPC5606BK or select Autodetect. If you select MPC5606B you get the error.
Martin
