Hello
I tried to use the I2C_RecvBlock for DSC (8257) - it does not work good.
It should send address in write mode, and switch to read mode without sending a STOP bit.
It enter read mode and read the number of bytes I need, but without sending the address first.
I work with CW 11 and automatic STOP option ON.
Is there a new PE addon ?
已解决! 转到解答。
 BlackNight
			BlackNight
		Yes, you can disable code generation in different ways, and you can do it for a single component too, see Disable my Code Generation | MCU on Eclipse
I hope this helps,
Erich
 BlackNight
			BlackNight
I hope this helps,
Erich
