Hi, I am using MULTILINK UNIVERSAL Rev.B. The programmer is working at some time not at most times.
When I used to program it works fine for some times but after that it stops working.
The same target board is working fine with another MULTILINK UNIVERSAL Rev.C.
What should I do now to rectify this problem?
Hi VIGNESHKUMAR P
Could you tell us what CodeWarrior version, OS and MCU are you using? Also, Have you tried to installed P&Emicro drivers in your IDE?
Jorge Alcala
Hi Jorge Antonio Alcala Vazquez,
Am using CW 10.6 under windows 7 and controller is KINETICS MKV10Z32VLC7(Using PORT-B in multilink). Yes I have Installed the latest P&E micro drivers.
And now the Universal Multilink is programming good for 5 to 10 times but afterwards it stops and shows the above error.
Vigneshkumar P
