MQX 4.2 plugin with CW 10.7
3,314 次查看
emanueletrapani
i installed MQX 4.2 on my system. I use CW 10.7.
I select the mqx 4.2 plugin from CW-help-Install new software.
i followed https://community.nxp.com/thread/386551 .
When i try to install MQX 4.2 plugin i get the error:
"An error occurred while collecting items to be installed
session context was:(profile=PlatformProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: binary,com.freescale.coldfire.PEx_root,1.0.4
No repository found containing: binary,com.freescale.coldfire.architecture_root,1.0.7
No repository found containing: binary,com.freescale.coldfire.buildtools_root,1.0.4
No repository found containing: binary,com.freescale.hcs.PEx_root,1.0.4
No repository found containing: binary,com.freescale.hcs.architecture_root,1.0.6
No repository found containing: binary,com.freescale.kinetis.PEx_root,1.0.4
No repository found containing: binary,com.freescale.kinetis.architecture_root,1.0.7
No repository found containing: binary,com.freescale.kinetis.gcc_root,1.0.4
No repository found containing: binary,com.freescale.kinetis.segger_root,1.0.2
No repository found containing: binary,com.freescale.mqx.v4.0_root,1.4.1.201401301129"
What is my mistake?
Thank you
标签 (1)
标记 (1)
5 回复数
2,931 次查看
ZhangJennie
Hi Emanuele,
I would suggest you try this site :
FSL MCU Eclipse Update Site - http://freescale.com/lgfiles/updates/Eclipse/MCU10_6_4/com.freescale.mcu.updatesite
There is no problem to install MQX 4.2 plugin on line from my side.
Jennie Zhang
2,931 次查看
emanueletrapani
I used this site yet.
2,931 次查看
ZhangJennie
I tested above update link on my side. it works normally.
I wonder the problem is on your network connection.
Please change another network, or you can also try disable firewall.
Jennie Zhang
2,931 次查看
Have you get the MQX installed ?
https://community.nxp.com/docs/DOC-102287
Alice
2,931 次查看
emanueletrapani
yes, 4.2 version of MQX.
