MPC5644A GPIO-GPDO Error
1,391件の閲覧回数
tgc-yilmaz
I'm using mpc5644a. I have set the 124th pin as GPIO output pin. However, I have observed that the value assigned to register GPDO [124] is set in register GPDO [123]. At the same time, I observed that this happened from pin 101 to pin 145. (Address has been defined twice for GPDO [101].)
NOTE: The same is true for GPDI[101]. However, no shift was observed in the GPDI[] registers.
What is the reason for this situation?
If there is an error, is there a published error record that describes this situation? Can you help with this?
Thanks in advance.
0 返答(返信)
