Lockup with CW3.1 for HS08
3,313 次查看
johnm
I am using a standard registered version of CW 3.1 for HCS08.
When using it the program will lock up completely, usually after a few minutes.
This happens even when just browsing code.  It happens pretty much every time
I use CW.  I am running Win XP SP1, but could possibly get SP2 installed if it may help.
John
标记 (1)
2,408 次查看
J2MEJediMaster
Specialist I
Are you using a firewall? That's been known to cause some problems, particularly if you're using a floating license. Also, go to the bottom of this Web page, and try entering the search string "Codewarrior hang" (no quotes), and examine some of the threads on this subject.
---Tom
Message Edited by J2MEJediMaster on 2006-09-27 09:36 AM
2,409 次查看
J2MEJediMaster
Specialist I
---Tom
2,408 次查看
Alban
Senior Contributor II
I had similar trouble on CW 4.5 for S12 which disappeared when I re-installed Symantec Anti-Virus.
Alban.
