Linker file, Documentation
louishdy
I am using CodeWarrior™ Development Studio for MPC55xx/MPC56xx Version 2.10 with the PowerPC MPC5644A (core e200z4). I don't know if a documentation with explanations on LCF file exists.
I alreday searched on the website and i found this : http://cache.nxp.com/files/soft_dev_tools/doc/app_note/AN4498.pdf?fsrch=1&sr=3&pageNum=1 (ANN448).
http://cache.nxp.com/files/soft_dev_tools/doc/app_note/AN4497.pdf?fpsp=1&WT_TYPE=Application%20Notes... (AN447)
But, everything is not explained. So for a beginner like me, it is not easy to understand everything.
Thank you for your help.
Louis
martin_kovar
Hi Louis,
please look at the documents in the attachment. These documents are part of CodeWarrior installation. Both documents are similar (almost the same), but it is possible there are some details, which could be helpful for you.
Martin
louishdy
Thank you Martin :smileyhappy:
