Frank.
unfortunately CW eclipse version doesn't support HC08 programming.
One if the importance aspect is that HC08 device uses MON08 interface but CW eclipse doesn't support.
I suggest you install CW6.3 on 64bit win7 with this workaround
Install CodeWarrior 6.3 Windows 7 & 10 x64 directly (Classic version)
Hope this helps!
Jennie Zhang
