Linkage Conflict - variable redefinition - CW 6.3
6,821 次查看
ignisuti
I'm getting the following when I compile:
Warning : external/internal linkage conflict with previous declaration
HARDWARE.c line 52   static unsigned char digitalInput1TimerEnable = FALSE;
 I have a file named HARDWARE.c that contains this line of code:
and also a HARDWARE.h header file that contains this line of code:
extern unsigned char digitalInput1TimerEnable;
 This variable is not defined anywhere else in my code. Why would I be getting this warning?
标记 (1)
5,388 次查看
kef
Specialist I
static variables can not be exported to other C files with extern. static's are always private to the C file, you define them in. Either remove static keyword from variable definition or extern from declaration. Your favorite C book should tell you the same.
5,389 次查看
kef
Specialist I
5,388 次查看
ignisuti
Duh... I'm embarassed now.
Thanks Kef!
