Line # display.
Line # display.
4,463 次查看
tmyint
Is there a way to display line numbers at the left margin beginning at the top of the document? This is in CW V5.0. thanks.
Thm
标记 (1)
2,436 次查看
CrasyCat
Specialist III
Hello
No this is not possible. Note that when you place the cursor on a specific line in an edit window, you can see the corresponding line number in the edit window status bar.
CrasCat
2,437 次查看
CrasyCat
Specialist III
Hello
CrasCat
2,436 次查看
GonzaloVictorio
That's bad...
In general I don't like that much Codewarior editor... they should take a look at the VS2005 editor and grab some ideas...
