J-TAGE use Trace function
4,634 次查看
smecolive
Does J-TAGE can enable Trace function in Code Warrior Development Studio?J-TAGE use more wire,why SWD can enable Trace but J-TAGE could not.I use J-Link debugger.And I want to know does Code Warrior Development Studio have Keil-like tracking function?Such as Logic analyzer.etc.Please help.
4,581 次查看
Robin_Shen
Tutorial: Getting ETM Instruction Trace with NXP Kinetis ARM Cortex-M4F
You can find the information: As shown above, the SWO trace pin is shared with the JTAG TDO pin. So this means that SWO cannot be used with JTAG, it only can be used with SWD in Tutorial: Using Single Wire Output SWO with ARM Cortex-M and Eclipse
Please check if Data Visualization is that you need(C:\Freescale\CW MCU v11.1\MCU\Help\PDF\Profiling and Analysis Users Guide.pdf)
6 回复数
4,628 次查看
ZhangJennie
HI @smecolive
What's your chip part number thus we can assign right engineer for your question.
Jun Zhang
4,619 次查看
smecolive
K60FN1M0
4,600 次查看
Robin_Shen
Hi  smecolive,
By J-TAGE, do you mean J-Trace or JTAG interface? I haven't used the Trace of CodeWarrior, so it's not clear whether you are using ETM or ETB or SWO for trace.
If you are using SWO trace, then it must select JTAG mode.
Robin
4,597 次查看
smecolive
I have used ETB to trace.About SWO I think my J-Link is piracy,No SWO function.Can you explain to me what ETM is? I think if I am using SWO trace,then it must select SWD mode,Please confirm it again.And I want to know does Code Warrior Development Studio have Keil-like tracking function?Such as Logic analyzer.etc.I am looking forward to your reply.Thanks a lot.
4,582 次查看
Robin_Shen
4,566 次查看
smecolive
Thanks for your reply,may be that's what I need.
