Is the MKL05Z32VLC obsolete?
3,071件の閲覧回数
zzabrahamzz
In this days I'm using the MKL05Z32VLC because is a MCU that have lower cost for my application, I want to use this MCU to control a LED displays and I need to use the timmer, but the SDK doesn't support this device, now I'm using CodeWarrior V11.1 for MCU, but I don't find more information to do use the timmer for this device.
Best regards.
5 返答(返信)
2,978件の閲覧回数
jingpan
Yes, there isn't KL05 SDK. If you use CodeWarrior, there is rarely demos for KL05 PIT/LPTMR. You can find demos for PWM/RTC in File->Import->CodeWarrior->Example Project_>Kinetis Example Projects(Processor Expert).
Another way is using KDS(Kinetis Develop Studio). Then you can refer to KL03 and KL25's sdk and demo. Drivers are same. It just need you to learn how to call them.
Jing
2,978件の閲覧回数
zzabrahamzz
Yes, I actually using CodeWarrior for this MCU I using the Processor Expert for control to the timer by DMA but I want debug by CMSIS DAP, is possible?
Thanks Jing Pan.
2,978件の閲覧回数
jingpan
Yes, CMSIS-DAP is fine. CodeWarrior can support it.
Jing
2,978件の閲覧回数
zzabrahamzz
And you have documentation for to make CMSIS-DAP link compatible with CodeWarrior, I searched information for this but I don’t found :smileysad:
Thanks and best regards Jing.
2,978件の閲覧回数
jingpan
What debug probe do you use? Do you use FRDM-KL05?
You can download driver from OpenSDA Serial and Debug Adapter | NXP
Jing
