Is it possible to set a breakpoint on write to a variable?
2,420 次查看
AndersJ
CW6.3, HCS08, USB Multilink and True-Time Simulator & Real Time Debugger.
 Is it possible to set a breakpoint on a write of a specific value or range of values to a variable?
Anders J
标记 (1)
2,148 次查看
J2MEJediMaster
Specialist I
It should be possible to set a watchpoint that monitors a change to a memory location. Consult the Microcontrollers Debugger Manual (CWMCUDEBUGGERRM.pdf), chapter 4, "Control Points" for more information.
---Tom
2,149 次查看
J2MEJediMaster
Specialist I
---Tom
