Insert "C function" in "Assembly program"
WT
The program is written in assembly using metrowerk codewarrior, however recently we were asked to insert "C code function" into the assembly file.
Is there a way to insert a "C code function" into an assembly program using metrowerks?
Your help is fully appreciated
Cheers
Its on a HCS08 processor
CrasyCat
Specialist III
Hello
I assume you want to call an ANSI C function from an assembly source file.
Am I right?
I would recommend to take a look at the HC08 assembler manual ({Install}\Help\PDF\Assembler_HC08.pdf where {Install} refers to your CodeWarrior installation directory).
There is a chapter "Mixed C and Assembler Applications" in there which explains how this works.
CrasyCat
CrasyCat
Specialist III
Hello
Am I right?
CrasyCat
