Index debug database Error
4,180 次查看
geremiadesarno
Hello everyone,
once installed CW 10.7, when I start it an error occurs (attached): Cannot index debug database.
Could someone tell me how to avoid it?
Thank you!
4,107 次查看
TICS_Fiona
Hello Geremia
Did you install and run CodeWarrior v10.7 as administrator?  I found a similar issue as below, hope it could help!
https://community.nxp.com/message/812251?commentID=812251#comment-812251
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
4,107 次查看
geremiadesarno
Hello Fiona,
thank you for your quick reply;)
I installed again CW and now it works well, without the error mentioned!
Geremia De Sarno
4,107 次查看
TICS_Fiona
Hello Geremia
You are always welcome. I'm very glad to know that you have solved the problem.
Thanks for choosing our products!
Best Regards
Fiona Kuang
