Import a project.wsd file though commandline?
已解决
跳至解决方案
1,770 次查看
rossrhone
Is there a way to import a Project file via command line argument in Codewarrior 10.4 microprocessors? Example I want to import a project.wsd file and then be able to build the entire workspace via command line.
Ross
标签 (1)
1 解答
1,637 次查看
jorge_a_vazquez
Hi Ross Rhone
It seems that you are getting help for this topic in this thread: How to change references by command line?
Jorge Alcala
在原帖中查看解决方案
1 回复
1,638 次查看
jorge_a_vazquez
Hi Ross Rhone
Jorge Alcala
