How to suppress assembler warnings?
2,802 次查看
namfuak
Is there any way to temporary suppress CW assembler messages in assembly code, like #pragma warning does in C? -WmsgSd is not good, because I don't want to disable the warning totally, but for a specific code region only
标记 (1)
2,138 次查看
CrasyCat
Specialist III
Hello
Macro assembler does not support a way to disable messages for a portion of the assembler file only.
This can only be done on the command line for the whole source file.
CrasyCat
2,139 次查看
CrasyCat
Specialist III
Hello
CrasyCat
2,138 次查看
namfuak
Thanks!
