How to select "generate code" selection for SetPeriodTicks within SystemTimer1
2,912 次查看
MWMinor
Has anyone experienced difficulties changing the value for SetPeriodTicks to generate code within the SystemTimer1 for MQXLite...?
I'm using PEv10.6 and my target processor is on a TWR-KL25Z48M board.
I've checked Counter restart is set to On-match within properties but the SetPeriodTicks don't generate code is grey'd out.
Ken
2,712 次查看
Hello Ken,
I received the answer from PE team ,
" the inherited component TimerUnit_LDD where the SetPeriodTicks is disabled by the MQXLite component's template. The SetPeriodTicks method is not allowed when the TimerUnit_LDD component inherited by MQXLite (this functionality is not supported by the MQXLite component)."
When you new add the component "TimerUnit_LDD " , it can cofiugure the SetPeriodTicks ,
Alice
5 回复数
2,712 次查看
Hello Ken,
"PEv10.6" ?  Does the "PE" meaning the Processor Expert on CodeWarrior ? or PExDriver ?
If the former , what about the version of CW .
if the latter, as far as i know  the latest version is 10.4, where can find the  10.6, thank ! I will test it on my side .
Alice
2,712 次查看
MWMinor
Hello Alice
Thanks for replying.
Yes V10.6 is the version of CodeWarrior.
If you use the project wizard to generate a new MQXLite project and go into the SystemTimer1 component and use the component inspector to view the methods - you will see the SetPeriodClicks - "Don't generate code" is greyed out making changing it impossible....
Is this a bug in Processor Expert component or am I missing something..?
Ken
2,713 次查看
Hello Ken,
Alice
2,712 次查看
MWMinor
Many thanks.......
Ken
2,712 次查看
Hello Ken,
I have test on my side, it also like yours , and i will ask for the PE expert , i will tell you .ASAP .
Alice
