How to see the speed clock (Bus frequency) configuration in debug perspective for eclipse 10.2?
已解决
跳至解决方案
3,218 次查看
orlandozapata
I am using a MCU51QE128, and  I want know how to see the clock speed that was configurate in my MCU using codewarrior development studio - eclipse 10.2 in debug perspective, When I worked in codewarrior 6.3 I could see this speed clock in the command window when this was configured step by step . Somebody know How find this window or what should I do to see the speed clock confugured in my proyects using eclipse 10.2? I want to see something like the picture shows.
My Code:
void Config_Reloj(void){
ICSC1=4;                  //ajusta el reloj interno
ICSC2=0;                  //frecuencia de bus de 26´748.225hz
ICSSC=0X70;
ICSTRM=0X40;
SOPT1=0X12;               //desactiva el reset
Thanks for your help and apologize for my english
标签 (1)
1 解答
3,004 次查看
ZhangJennie
please see bus clock as attached screenshots
在原帖中查看解决方案
1 回复
3,005 次查看
ZhangJennie
