How to handle CW assembler for one main source file and more secondary file in CW 5.0 for HCS(X)12 ?
1,079 次查看
MarkMa
Hi all,
I am working on absolute an assembler project, I want to using one main source file an more secondry file to buildup the project, but i meet some problem. Please help to check.
My environment is: WinXP SP3, CW 5.0 for HCS(X)12
I attach my project file
Thank you and best regards
标记 (1)
886 次查看
CrasyCat
Specialist III
Hello
  If you intend to use absolute assembly, your application needs to be encoded in one single assembly unit.
  So you should have one single .asm file in your project. You can then include other files in there.
  Do not use the extension ,asm for include files. The project manager will attempt to assemble all files
  with this extension.
CrasyCat
887 次查看
CrasyCat
Specialist III
Hello
CrasyCat
