How to generate a text file of all the compiler warnings?
2,495 次查看
sep2kor
Hi..
I want to know...how to genrate a text file of all the compiler warning shown by CodeWarrior?
I am using CodeWarrior IDE version 5.9.0.
标记 (1)
1,956 次查看
kef
Specialist I
1) In Errors 7 Warnings window click on any message
2) Press on keyboard Ctrl C. This will copy all unfiltered messages to clipboard.
3) Open txt file in text editor and press Ctrl V to paste messages to text editor.
4 回复数
1,957 次查看
kef
Specialist I
1,956 次查看
Emac
I have found the above method to be the only one that works.
There are compiler options that are "supposed to" print out the errors and warnings to an output file but (hint hint FREESCALE, if you are listenting) they don't work.
Does anyone know if FREESCALE has a bugzilla like reporting system?
1,956 次查看
CrasyCat
Specialist III
Hello
I did some test locally with CodeWarrior for HC12 V5.1.
Adding following lines to my Compiler Command line makes CodeWarrior generate a file main.err when compiling file main.c:
   -Env"ERRORFILE=%f.err" -WOutFileOn
The .err file is created in the same directory as the source file.
CrasyCat
1,956 次查看
kef
Specialist I
I don't know what bugzilla is, but what about submitting service request?
https://www.freescale.com/webapp/servicerequest.create_SR.framework
Though, I think IDE 5.9 is going to be abandoned :smileysad:. Bad to ones who like it, goot for those who want Eclipse.
