您尝试访问的信息已永久删除。
I use a FRDM-KE06Z board to develop a application.
I can't find any predefined like delay_ms() or delay()
Any good way to calculate the machine cycles that I can write a delay function easily?
已解决! 转到解答。
You might have a look at the open source Wait Processor Expert component which is available on SourceForge, see
McuOnEclipse Releases on SourceForge | MCU on Eclipse
It comes with various busy wait routines:
If you are not using Processor Expert: you simply generate the code and use the WAIT1.c and WAIT1.h files in your project.
I hope this helps,
Erich
