How to build a library in CodeWarrior Studio for s12?
1,648 次查看
zoe1867
Hi guys.
I'm using mc9s12xs128 in my prj. , and I don't konw how to use codewarrior to build a library, can somebody give me a guide?
many thanks.
标记 (1)
1,411 次查看
CrasyCat
Specialist III
Hello
In order to build a library:
  - Create your project as usual for the mc9s12xs128 MCU
  - Open the Target settings dialog (Press ALT + F7)
  -  In the Target > Target Settings panel set Linker to Libmaker for HC12.
  - Switch to panel Target > Libmaker for HC12 to indicate the name of the generated library.
  You can remove the Startup Code and linker Files from the project as they are not needed for an object library.
CrasyCat
1,412 次查看
CrasyCat
Specialist III
Hello
CrasyCat
