I have tried global accessing by adding #pragma CONST_SEG __GPAGE_SEG XXX in my code
But CodeWarrior 5.1 still report an error of L1102: Out of allocation space in segment PAGE_F9 at address 0xF98000
解決済! 解決策の投稿を見る。
I will answer myself. The answer is found in S12X Examples.pdf.
1) Add #pragma statements in the source code that tell the compiler how to access these
variables and under what name (segment name) these variables can be referred to by the
linker:
a) #pragma DATA_SEG __GPAGE_SEG GLOBAL_RAM
and/or
b) #pragma CONST_SEG __GPAGE_SEG GLOBAL_FLASH
2) In the linker parameter file (extension .prm), place this segment into the correct
memory ranges.
a)
PLACEMENT
PAGED RAM_0F_GLOBAL = READ_WRITE 0x0F8000'G TO 0x0FBFFFF'G;
/* 16 kByte global address range covering RAM_F8 .. RAM_FB */
END
b)
PLACEMENT
FLASH_7E_GLOBAL=READ_ONLY 0x7E0000'G TO 0x7EFFFF'G;
/* 64 kByte global address range covering PAGE_F8..PAGE_FB */
END
Note: Make sure to delete of comment the corresponding definitions for the banks that
overlap this global addresses!
3) make sure to specify the option -D__FAR_DATA on the compiler command line. This
will enable the correct initialization in the startup code.
4) any pointer pointing to global data needs to be qualified with “__far”:
c
har *__far myPtr;
linker:
and/or
memory ranges.
a)
PLACEMENT
END
b)
PLACEMENT
END
c
har *__far myPtr;
Hello Xuan,
Thanks for your sharing.
Have a nice day!
Alice
