Hot to program from command line?
4,566 次查看
PW_CTL
Hello.
I am searching for a fast way to program some MCUs with a usb bdm programmer (P&E multilink cable). Is it possible with the application "burner.exe"? Is there any simple bdm programmer from command line?
Thanks.
标记 (1)
2,845 次查看
stanish
See the debugger manual ("<CodeWarrior install directory>\help\pdf\Debugger_HCxx.pdf", search section "Command Line Options").
Stanish
5 回复数
2,845 次查看
stanish
check the thread here. It's dedicated to HC12 but it might help you.
Stanish
2,845 次查看
PW_CTL
Thanks. Probably the P&E software is the best option, but right now it is enough for me with hiwave.
hiwave.exe C:\...\project.s19 -W -Prod=C:\...\P&E_ICD.ini -instance=sim
It works succesfully after selecting the MCU and two clicks. Do you have documentation about hiwave.exe and its paramaters? I would like to do an automatic process launched by command line, if possible.
Thanks for your help!
2,846 次查看
stanish
Stanish
2,845 次查看
PW_CTL
Thanks for your help. I got my command-line programmer!.
2,845 次查看
peg
Senior Contributor IV
P&E Micro include a commnd line programmer with their S08 Programming software (PROGHCS08)
