Help with debugging
Help with debugging
2,904 次查看
MathiasC
When I try to debug i get 101errors and 132warnings,
I use CW6.1 (on Vista)  and using target HC(s)08.
All errors and warnings referes to \ColdFire_support\msl\MSL_C\MSL_Common\Include\xxxx.h
xxxx.h  = mslGlobals.h or ansi_parms.h for example
Im new to using this software so please explain very carefully =)
/Mathias
标记 (1)
1,886 次查看
CrasyCat
Specialist III
Hello
This question is not specific enough.
What sounds strange to me is you are telling you are building an application for HC08 and you are linking coldfire library to the application.
This cannot work.
I would suggest you to start with a brand new project. Use the project wizard to create your project and select the appropriate CPU & MCU from there.
This should fix all your problems.
CrasyCat
1,886 次查看
MathiasC
thanks for your help.
I will try that!
Im just trying to kick on an old project, and ive just followed the instructions
1,887 次查看
CrasyCat
Specialist III
Hello
This cannot work.
CrasyCat
