HELP!!! Having General issues with Codewarrior and can't figure out why
982 次查看
AK88
Is anyone able to help out with a couple of questions i have already posted to this forum?  I have a project due in a week and codewarrior just started to not communicate with my device.  Don't understand the issue would like some insight.
标记 (1)
847 次查看
CrasyCat
Specialist III
Hello
Did you consider submitting a service request through our on-line support web page?
You should be able to get faster response this way.
Click here to submit a service request.
In order to save time make sure to
  - log 1 problem per service request
  - attach a project reproducing the trouble.
  - specify which version of the tool chain you are using.
       To retrieve that info for version < 10.0:
          - Start CodeWarrior
          - Select Help -> About Freescale CodeWarrior
          - Click on "Install Products"
          - CodeWarrior version used is displayed on top in the Installed Products dialog.
       To retrieve that info for version > 10.0:
          - Start CodeWarrior
          - Select Help -> About CodeWarrior Development Studio
          - The version number and build number we need are the one specified under "Installed Products"
CrasyCat
848 次查看
CrasyCat
Specialist III
Hello
          - Start CodeWarrior
          - Start CodeWarrior
CrasyCat
