HC12: Non Volatile Memory Control Utility (NVMC)
3,399 次查看
Br
Where Can I find the Non Volatile Memory Control Utility (NVMC).
Emerson
Message Edited by CrasyCat on 2007-04-13 11:43 AM
标记 (1)
2,369 次查看
CrasyCat
Specialist III
Hello
I assume you are looking for the NVMC dialog. Am I right?
This dialog is not available for all connections. You can normally open it from the Connection menu (Menu Multilink/CyclonePro for instance for HC12 tools) using menu entry "Flash ...".
CrasyCat
2,369 次查看
Br
Thanks for your contribution.
Emerson
2,370 次查看
CrasyCat
Specialist III
Hello
CrasyCat
