GetError
GetError
anil
Occasionally, the processor expert function for receiving a serial port character for a 9s12 returns
ERR_COMMON.
The comments state to call the
GetError method for error specification
1. I can't find where the GetError Method is included
2. What can cause the ERR_COMMON to be returned
** ERR_COMMON - common error occurred (the
** GetError method can be used for error
** specification)
CrasyCat
Specialist III
Hello
Which Bean are you using for your SCI?
If you open the Bean Inspector for your SCI bean and go to the Methods tab, you can activate code generation for method "GetError" there.
Calling that function will allow you to detect whether you have a buffer overflow, a framing error or a parity error.
I hope this helps.
CrasyCat
CrasyCat
Specialist III
Hello
I hope this helps.
CrasyCat
