From CW classic to eclipse: Out of allocation space in segment ROM2 at address 0xF88D
florianaugustin
Hello!
I'm currently trying to adapt a HCS08AW16 Project from Codewarrior Classic to the new eclipse-based IDE.
I did the following steps:
- Load source files, adapt pathes and compiler settings
- Import Linker file *.prm from old project and adapted linker settings to new filename
- Import Lib file "ansiis.lib" and "ansiis.lst" from codewarrior classic project and deleted "mc9s08aw16.c" and "mc9s08aw16.h" from new project
- Deleted "derivative.h" from new project
I experimented a lot but I always get the following errors:
mingw32-make: *** [....abs] Error 1
I don't know where to start because I did not change any of the files that were imported.
Thank you for help!
Florian
ZhangJennie
hi Florian
you should not use the default prm file.
please check in your prm file if you have all the memory for loading your code?
please check if you have  -OnB=b  to your compiler option?
if still have problem, please upload your project here. I can check it on my side directly. thanks!
Zhang Jun
