Float compute error
Float compute error
2,738 次查看
alonjun
PC: Windows XP
IDE: CodeWarrior for S12x V5.1
Chip: S12XEP100
Code:
When run this code, VTST_BattOverCurrTh1_A not equal VTST_BattOverCurrTh2_A and get a wrong value
So I view assembly code,
When execute SEX  A,X  JSR  _FUFLOAT, get a wrong value, it seems SEX  A,X  wrong, compiler's bug?
Original Attachment has been moved to: Project.zip
5 回复数
2,509 次查看
ZhangJennie
thanks for posting your questions.
can you please upload your entire demo project folder in zip format here. thus i can debug and check your problem directly. thanks!
Jennie Zhang
2,509 次查看
alonjun
Have uploaded the project, thank you!
2,509 次查看
ZhangJennie
I reproduced your problem. Will escalated it to development team.
for the moment please define HVSamples3_o2 as unsigned short as a workaround:
unsigned short HVSamples3_o2[8] = {0x0,0x0,0x10,0x0,0x10,0x0,0x0,0x0};
thus
both VTST_BattOverCurrTh1_A and VTST_BattOverCurrTh2_A will be 40.95996.
Jennie Zhang
2,509 次查看
alonjun
Thanks, it is not the best way to fix this problem, my code generated by Simulink, I can not control all the code. If it is the compiler's bug, hope can fix it fast. It is also exists in CodeWarrior for S12x V5.2, thank you!
2,509 次查看
ZhangJennie
Hi Alon.
this problem has been reported to development team. I will let you know if I get any update.
Jennie Zhang
