File error 206003
File error 206003
7,100 次查看
jafriede
I just installed CodeWarrior Development studio that came with the EVB9S08DZ60 Starter Kit. When I try to open Demo.mcp in:
C:\Program Files\Freescale\CodeWarrior for HC08 V5.1\(CodeWarrior_Examples)\HCS08\Evaluation Board Examples\EVB9S08DZ60\C\Demo, I get the following error:
File error 206003 ... Unable to open project because file access was denied
I did the online updates after the install. The Help:About says:
CodeWarrior IDE version 5.7.0
Build 2015
Any ideas? Thanks
标记 (1)
4,443 次查看
jafriede
I figured it out. I was not aware that the "security" tab was not available in XP Professional without disabling "simple file sharing". I found this on experts-exchange.com. I don't know why the permissions were set up this way. Must have been something the way CodeWarrior installed. Thanks for your help.
6 回复数
4,443 次查看
CrasyCat
Specialist III
Hello
Can you check whether you have write access to the file "C:\Program Files\Freescale\CodeWarrior for HC08 V5.1\(CodeWarrior_Examples)\HCS08\Evaluation Board Examples\EVB9S08DZ60\C\Demo\demo.mcp "?
You need write access to the .mcp file to be able to build it.
CrasyCat
4,443 次查看
jafriede
I am the only user on this machine (Windows XP SP2) and have verified that the "Read Only" attribute is not set on this file. I do not have this problem with any other application.
4,443 次查看
CrasyCat
Specialist III
Hello
Some other questions.
   - Is the issue arising for that project only or for any project?
   - Do you have write access to "C:\Program Files\Freescale\CodeWarrior for HC08 V5.1"?
   - Do you have administrator or user right to C:\Program Files\Freescale\CodeWarrior for HC08 V5.1?
   - Also I need to know exactly what you did install.
       To retrieve that info:
           - Start CodeWarrior
           - Select Help -> About Freescale CodeWarrior
           - Click on "Install Products"
           - CodeWarrior version used and service packs installed are displayed on top in the Installed
              Products dialog.
  I need to see a list of all SP installed.
CrasyCat
4,444 次查看
jafriede
4,443 次查看
jafriede
I tried opening the CAN and LIN projects also with the same results. My account is an Administrator account and there are no other users on my machine. As far as write access, The file demo.mcp is not marked read-only, but that directory as well as every directory on my hard drive has "read only" checked if you right click -> properties. I can change it but it changes right back.
As a test, I tried to save a test file from notepad and it would not save. However, I can save it to other places within c:\Program Files. I thought with an Administrator account there would be no issue with permissions?
Here is the info you requested:
Installed Products:
CodeWarrior Development Studio for Freescale HC08 5.1, build 6124.
CodeWarrior Development Studio for Freescale HC08 5.1 Compiler Patch 1, build 6192.
CodeWarrior Development Studio for Freescale HC08 5.1 HCS08/RS08 Open Source BDM Final Service Pack, build 6290.
CodeWarrior Development Studio for Freescale HC08 v5.1, Service Pack AP64/AP64A, build 060824.
CodeWarrior Development Studio for Freescale HC08 v5.1, Service Pack ASAZ60A, build 060810.
CodeWarrior Development Studio for Freescale HC08 v5.1, Service Pack EY16A, build 060821.
CodeWarrior Development Studio for Freescale HC08 v5.1, Service Pack GP_GT, build 060829.
CodeWarrior Development Studio for Freescale HC08 v5.1, Service Pack GT16A, build 060630.
CodeWarrior Development Studio for Freescale HC08 v5.1, Service Pack JB8, build 060727.
CodeWarrior Development Studio for Freescale HC08 v5.1, Service Pack JR12, build 060821.
CodeWarrior Development Studio for Freescale HC08 v5.1, Service Pack JW32, build 060721.
CodeWarrior Development Studio for Freescale HC08 v5.1, Service Pack PE2.99, build 070119.
CodeWarrior Development Studio for Freescale HC08 v5.1, Service Pack QD4, build 061215.
CodeWarrior Development Studio for Freescale HC08 v5.1, Service Pack QY4A, build 060609.
IDE Version: 5.7.0 Build 2015
Plugins: 46
ASINTPPC.dll 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 11:28 AM 628K
CmdIDE.exe 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 12:03 PM 41K
IDE.exe 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 11:58 AM 10.10M
IDENewDialog.dll 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 11:38 AM 201K
IDE_MFC60cw.dll 6.00.8665.0 6.0.8665.0 6.0.4.0 4/28/2006, 11:31 AM 1.59M
IDE_MSL_DLL90_x86.dll 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 11:26 AM 296K
InstallHelperKeys.exe No Version Info 0.0.0.0 0.0.0.0 6/4/2003, 4:23 PM 76K
lmgr8c.dll No Version Info 0.0.0.0 0.0.0.0 2/15/2004, 5:02 PM 832K
MWCore5_0.dll 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 11:32 AM 236K
MWRADUtils.dll 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 11:34 AM 260K
Mwregsvr.exe 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 11:43 AM 36K
MWRegSvrWinApp.exe 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 11:43 AM 36K
PluginLib.dll 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 11:29 AM 120K
PluginLib2.dll 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 11:29 AM 120K
PluginLib3.dll 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 11:29 AM 120K
PluginLib4.dll 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 11:29 AM 84K
PluginLib5.dll 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 11:29 AM 84K
PluginLib6.dll 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 11:29 AM 84K
SHW32.DLL 4.0.1.0 4.0.1.0 2/10/2000, 5:15 PM 110K
sunvmhub.dll No Version Info 0.0.0.0 0.0.0.0 1/29/2002, 2:20 PM 49K
tcl83.dll 8.3.1 8.3.2.1 8.3.2.1 10/15/2000, 10:28 PM 605K
xerces-2_2_0.dll 2, 2, 0 2.2.0.0 2.2.0.0 4/28/2006, 11:43 AM 2.14M
Bin\Plugins\com
TipOfTheDay.dll 1,0,0,6124 1.0.0.6124 1.0.0.6124 5/5/2006, 2:15 PM 64K
PE_prelink.dll 1, 0, 0, 4 1.0.0.4 1.0.0.4 8/8/2005, 12:34 PM 95K
PE_Plugin.dll 3.85.0.7060 3.85.0.7060 3.85.0.7060 12/22/2006, 9:56 AM 6.60M
PE_options.dll 1, 0, 0, 13 1.0.0.13 1.0.0.13 8/8/2005, 12:33 PM 32K
PackAndGo.dll 1,0,0,6124 1.0.0.6124 1.0.0.6124 5/5/2006, 2:17 PM 344K
MWActivate.dll 5.7.0.2015 5.7.0.2015 5.7.0.2015 4/28/2006, 12:04 PM 600K
HC(S)08Wizard.dll 5.2.6141 5.2.0.6141 5.2.0.6141 5/22/2006, 9:06 PM 877K
CPPCodeCompletion.dll 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 12:03 PM 808K
Bin\Plugins
Bin\Plugins\compiler
PCLintCompiler.dll 1.5 1.5.0.5 1.5.0.5 9/4/2003, 4:58 PM 80K
OsekCompiler.dll 2, 1, 5, 0 2.1.5.0 2.1.5.0 10/19/2005, 12:33 PM 76K
hw_hc08_importer.dll 5.0.14.6124 5.0.14.6124 5.0.14.6124 5/5/2006, 2:15 PM 87K
hw_hc08_compiler.dll 5.0.14.6124 5.0.14.6124 5.0.14.6124 5/5/2006, 2:15 PM 87K
hw_hc08_assembler.dll 5.0.14.6124 5.0.14.6124 5.0.14.6124 5/5/2006, 2:15 PM 87K
Bin\Plugins\Editor
MWE_Common_Coloring No Version Info 0.0.0.0 0.0.0.0 12/29/2004, 8:23 PM 29K
HC08_Coloring No Version Info 0.0.0.0 0.0.0.0 6/23/2005, 4:12 PM 38K
Bin\Plugins\linker
PCLintLinker.dll 1.5 1.5.0.5 1.5.0.5 9/4/2003, 4:58 PM 84K
hw_hc08_linker.dll 5.0.14.6124 5.0.14.6124 5.0.14.6124 5/5/2006, 2:16 PM 92K
ExternalBuildLinker.dll 5.7.0.2015 5.7.0.2015 5.7.0.2015 4/28/2006, 12:25 PM 80K
hw_hc08_libmaker.dll 5.0.14.6124 5.0.14.6124 5.0.14.6124 5/5/2006, 2:16 PM 92K
BatchRunnerPostLinker.dll 2.0.0 Build 0006 2.0.0.6 2.0.0.6 7/9/2004, 12:01 PM 40K
BatchRunnerPreLinker.dll 1.0.0 build 0002 1.0.0.2 1.0.0.2 7/9/2004, 12:01 PM 42K
Bin\Plugins\preference_panel
PCLintSettings.dll 1.5 1.5.0.5 1.5.0.5 9/4/2003, 4:58 PM 82K
PCLintOptions.dll 1.5 1.5.0.5 1.5.0.5 9/4/2003, 4:58 PM 41K
PBatchRunnerPreLinker.dll 1.0.0 build 0003 1.0.0.3 1.0.0.3 9/11/2003, 9:31 PM 29K
PBatchRunnerPostLinker.dll 2.0.0 Build 0004 2.0.0.4 2.0.0.4 9/11/2003, 9:31 PM 39K
OsekPanel.dll 2, 1, 5, 0 2.1.5.0 2.1.5.0 10/19/2005, 12:32 PM 70K
hw_hc08_linker_panel.dll 5.0.14.6124 5.0.14.6124 5.0.14.6124 5/5/2006, 2:16 PM 89K
hw_hc08_libmaker_panel.dll 5.0.14.6124 5.0.14.6124 5.0.14.6124 5/5/2006, 2:16 PM 89K
hw_hc08_importer_panel.dll 5.0.14.6124 5.0.14.6124 5.0.14.6124 5/5/2006, 2:16 PM 89K
hw_hc08_compiler_panel.dll 5.0.14.6124 5.0.14.6124 5.0.14.6124 5/5/2006, 2:16 PM 89K
hw_hc08_burner_panel.dll 5.0.14.6124 5.0.14.6124 5.0.14.6124 5/5/2006, 2:16 PM 89K
hw_hc08_assembler_panel.dll 5.0.14.6124 5.0.14.6124 5.0.14.6124 5/5/2006, 2:16 PM 89K
PExternalBuild.dll 1.0.1.0 1.0.1.0 1.0.1.0 4/28/2006, 12:24 PM 64K
pMWCVS.dll 1.3.0.2015 1.3.0.2015 1.3.0.2015 4/28/2006, 12:25 PM 64K
pmwSourceSafe.dll 5.5.1.40704 5.5.1.40704 5.5.1.40704 4/13/2004, 3:47 PM 29K
Bin\Plugins\Support
CPlusSourceGen.dll 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 12:00 PM 272K
MWComBase.dll 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 11:29 AM 64K
MWComHelpers.DLL 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 11:33 AM 452K
MWRadModel.dll 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 11:39 AM 572K
Bin\Plugins\version_control
mwcvs.dll 1.3.0.2015 1.3.0.2015 1.3.0.2015 4/28/2006, 12:25 PM 228K
mwSourceSafe.dll 1.0.3.716 1.0.3.716 1.0.3.716 4/13/2004, 3:47 PM 137K
VCSClearCase.dll 1.1.2.1999 1.1.2.1999 1.1.2.1999 9/29/2004, 3:28 PM 76K
Bin\resource
CPlusResources.dll 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 11:59 AM 24K
ExternalBuildResources.dll 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015 4/28/2006, 12:25 PM 6K
IDEAuxiliaryResources.dll 5.7.0 Build 2015 5.7.0.2015 5.7.0.2015
4,443 次查看
Alban
Senior Contributor II
Please check that all project files have read and WRITE access for the user/system.
Alban.
