Error:A23014:Not a LISA/HCS12Z instruction or directive
991件の閲覧回数
MCMIKE
I'm working on a project based on C, we ported the program from S12ZVML64 to S12ZVMC128. The project is about brushless motor FOC, but every time I try to build the project I get the error "A23014:Not a LISA/HCS12Z instruction or directive". Need help.
976件の閲覧回数
ZhangJennie
HI MCMIKE
Normally the problem is due to assembler detects wrong instruction or directive. You need to check which line of code causes this error.
Or upload your project here thus we can check it here.
Best Regards
Jun Zhang
