Eclipse Bug in generating "Path Variable" with Variable reference in "Linked Resources"
1,808件の閲覧回数
mauriziostefane
In Project -> Properties -> Linked Resourced  generation of "Path Variable" with "Variable" reference doesn't work.
Eclipse does not write "${" and "}" on variable with relative errors in its interpretation.
Path Variable location is ".project" file and you can correct the problem typing "${" and "}" by hand.
タグ(3)
2 返答(返信)
1,535件の閲覧回数
tom_thompson
You need to file a service request on this issue. Click here to do that.
---Tom
1,535件の閲覧回数
mauriziostefane
Done !
Thanks Tom
