EXAMPLE PROGRAM FOR UART NEEDED
1,310件の閲覧回数
vinothkr
i am new to code warrior and i need example UART program for TRK-KEA128
1,199件の閲覧回数
Carlos_Mendoza
Hi Vinoth,
If you want to use CodeWarrior I would recommend you to use the following examples:
http://www.nxp.com/assets/documents/data/en/application-notes/AN4942.pdf
http://www.nxp.com/assets/documents/data/en/application-notes-software/AN4942.zip
Hope it helps!
Carlos Mendoza
Technical Support Engineer
