Does CW special or basic edition support Kinetis and MQX?
1,570 次查看
ayang
I am new to Kinetis and MQX and would like to evalute them. Does CW special edition (128KB limit to Kinetis) or basic edition (512KB limit to Kinetis) support Kinetis and MQX?
1,401 次查看
J2MEJediMaster
Specialist I
As you probably suspect, the Special and Stanard Editions might not have sufficient capabilities (in terms of code size limits or other restrictions) to work with the MQX RTOS. If you are going to evaluate the software, you might as well download the fully-featured Evaluation version of CodeWarrior and try it for 30 days to accurately assess the capabilities of the product, rather than trip over the limitations.
The short answer to your question is that the Special Edition and Standard Edition do support the Kinetis part.
---Tom
1,402 次查看
J2MEJediMaster
Specialist I
---Tom
