Debugger doesn't stop at breakpoints
2,813件の閲覧回数
joseperez
Hi!
I'm new at C programming and the Code Warrior IDE. I have a ColdFire V2 MCU on a board (MCF5213CAF80) and a PE Micro Multilink in order flash and debug it. I've been playing around with Code Warrior in order to understand the enviroment.
I'm trying to debug some code I wrote and I set some breakpoints, but when I hit resume, the debugger doesn't stop at the breakpoint. it didn't do it before and I tried debugging a different family of MCU and it stoped at the designated breakpoints.
I can only think it has something to do with my Multilink, but I want to know if there could be another thing causing it?
Best regards!
2,300件の閲覧回数
BlackNight
Can you check if you have turned on 'skipping breakpoints'? see Skipping Breakpoints | MCU on Eclipse
I hope this helps,
Erich
