Compare 2 dates
Compare 2 dates
2,796件の閲覧回数
MSI_Souza
I need compare two different dates. How I do?
I am using CodeWarrior S12(X) V5.0
Thanks.
タグ(1)
4 返答(返信)
2,465件の閲覧回数
Monica
Senior Contributor III
Claudio, are these replies useful?
We would like to know how is your project moving along!
Regards!
2,465件の閲覧回数
CrasyCat
Specialist III
Hello
Are you looking for time management function inside of the ANSI library?
The delivered library do not provide support for time management functions.
If you intend to use these functions in your application you need a dedicated hardware to handle time functions.
Comparing two different dates depends on how the device is programmed.
CrasyCat
2,465件の閲覧回数
usmanjavaid
what if cladio souza saves those 2 dates in two variables and put a check on their difference
when difference is zero the dates are same
similarly difference might be greater or smaller than 0
2,464件の閲覧回数
usmanjavaid
