Codewarrior won't open .mcp project file
1,911 次查看
zhaoqinsu
When trying to open the .mcp project file that others created (and is working fine on her codewarrior) I get the following error:
we are using the exact same versions of codewarrior and I am able to open and work with other codewarrior projects.
Who have met the same problem ?
1,464 次查看
BlackNight
can you share that .mcp file? Other than that, open it in a text editor to see its content, maybe you have stored the project as XML file?
I hope this helps,
Erich
