Codewarrior 10 compiler version?
3,096 次查看
irob
I'm required to state the compiler name and version in our company source code.  I've just upgraded to CW 10 and I'm having a hard time finding this.  Though during builds, I can see that Freescale migrated to GCC.
In the Help > About, I see a bunch of credits, but not specifically for the compiler.  The closest I can find is:
CodeWarrior HCS08 Debugger 10.1.0.FSL_b5490
Anyone else see the compiler?
标记 (1)
2,688 次查看
CrasyCat
Specialist III
Hello
Compiler version is not available in the About box.
In order to retrieve the compiler version number:
  - Open an Explorer window
  - Browse to {Install}\MCU\prog
  - Double click on chc08.exe
  - In the HC08 Compiler window select help > About and you should see the compiler version number.
CrasyCat
2,689 次查看
CrasyCat
Specialist III
Hello
CrasyCat
2,688 次查看
irob
Perfect, thanks!  I never would have found that.
