Codewarrior 10.6 Simulator
3,175 次查看
mayursavaj
We are using CW10.6 for kinetics.
How to Use Simulator in CW10.6???
Mayur
3 回复数
2,548 次查看
stanish
I'm affraid there is no Simulator for S12Z available in CodeWarrior for MCUs.
As far as I know there is simulator available in Cosmic development environment for S12Z (https://www.cosmic-software.com/s12z_des.php)
Hope it helps.
Stan
2,649 次查看
ZhangJennie
CW eclipse doesn't install simulator plugin for kinetis. There is no way to simulate chip run without connecting a board.
some 8bit and dsc chip has full chip simulator installed but not for kinetis.
Jennie Zhang
2,591 次查看
manjunathkm
Can i use simulator for S12Z micro for the same IDE 10.6 version?
