Codewarrior 10.6 Simulator
mayursavaj
We are using CW10.6 for kinetics.
How to Use Simulator in CW10.6???
Mayur
stanish
I'm affraid there is no Simulator for S12Z available in CodeWarrior for MCUs.
As far as I know there is simulator available in Cosmic development environment for S12Z (https://www.cosmic-software.com/s12z_des.php)
Hope it helps.
Stan
ZhangJennie
CW eclipse doesn't install simulator plugin for kinetis. There is no way to simulate chip run without connecting a board.
some 8bit and dsc chip has full chip simulator installed but not for kinetis.
Jennie Zhang
manjunathkm
Can i use simulator for S12Z micro for the same IDE 10.6 version?
