Codewarrior 10.5 view char pointers as strings
3,496 次查看
cruton
So this has been a problem since 10.2 apparently.  I just downloaded 10.5 and it still seems to be an issue.
If I declare a variable like this:
char * p="displayme";
it won't appear as a string in the debugger.
But if I declare it like this:
unsigned char * p="displayme";
It shows up as a string.  Is there any fix for this?
thanks
3,121 次查看
BlackNight
Hi Carl,
that might depend on the signess for character, and the toolchain used.
Below is what I get for GNU ARM gcc with CodeWarrior 10.5:
And I get it correctly under the variables view too:
Erich
4 回复数
3,122 次查看
BlackNight
Hi Carl,
Erich
3,121 次查看
cruton
I'm using for a board based on the Coldfire mcf54452 processor.  I'm not sure where to find the toolchain in Codewarrior, Codesourcery probably?  Maybe the m68k series aren't getting a lot of love in the recent versions of CW?
3,121 次查看
TICS_Fiona
The command line tools for Coldfire is under CodeWarrior 10.5 subfolder:
C:\Freescale\CW MCU v10.5\MCU\ColdFire_Tools\Command_Line_Tools
3,121 次查看
cruton
I was kind of hoping this would work itself out in 10.6 but it's still broken.  Any news on this?
