Code warrior development studio 10.6.
1,296件の閲覧回数
sagarmahajan
 I trying to change the PAToolsBaseDir and PAToolsDir.  I am able to change/edit the path and working successfully. However that is not dynamically changing meaning if I commit to Tortoise SVN and if someone else check out the path is not dynamically changing.
- Can I edit the path of Build variable PAToolsBaseDir and PAToolsDir to work dynamically?
- If yes How? Is there any documentation available?
Thanks..
1,139件の閲覧回数
ZhangJennie
Hi Amar,
I am not familiar with NVM but I am afraid CW eclipse doesn't have this dynamic build variable changing feature.
Here is an article from Erich about using Variables for building projects. I suggest you check it.
Eclipse Build Variables | MCU on Eclipse
Jennie Zhang
