Assembler Local Labels
1,563件の閲覧回数
matthewolson
Does the assembler for the CS08 devices offer a local label feature?  for example, instead of having to track short loops with a loopx label, the user could assign a character to be the first one of the label and then that particular label would be unique between the non-local labels before and after the local label.  If not, how do others create labels for short loops or branches in subroutines?
Thanks...ptp
1,492件の閲覧回数
Leojunin
I do not know what you say. If your relocatable assembler programs, each tag is private within .asm file. If what you have is a repetitive loop routine, you can program it into a macro. When you call the macro each tag is configured not to be repeated using \ @. Example:
MyMacro     MACRO               ;clear registers
               lda   #\1
               ldhx  #\2
loop\@         clr   0, x
               aix   #1
               dbnza loop\@
            ENDM
MyCode      SECTION
            nop
            nop
            MyMacro 4, RAMStart
            MyMacro 8, $230
            nop
;Generated code: green = macro expansion
MyCode      SECTION
            nop
            nop
            MyMacro 4, RAMStart
            lda   #4
            ldhx  #$80
loop_00001     clr  ,x
            aix   #1
            dbnza loop_00001
            MyMacro 8, $230
            lda   #8
            ldhx  #$230
loop_00002     clr  ,x
            aix   #1
            dbnza loop_00002
            nop
1,492件の閲覧回数
ZhangJennie
from my understanding, CW for HCS08 assembly doesn't have this feature.
Jennie Zhang
