Good day All,
Just an update to this thread I started...
I was finally able to instal CW 10.4, but the software just had too many issues that I got fed up with. As a consequence I did not use it for any projects. That being said I found out about CW 10.5 and decided to try it... what a difference in the installation. CW 10.5 installed without issue, drama, and in about 25 minutes total... about 10 minutes to install about 80% of it and then 15 minutes to install the remaining 20%. Everything installed without no problem. I then used 10.5 on a simple project and again everything worked perfectly. I will try 10.5 on a larger project, but so far I am feeling better about CW Eclipse. So, those of you who had 10.4 issues... dump 10.4 and just go to 10.5!
Cheers,
Sam
